After Market Muffler
As you all know I have a brand new Camaro. Question is will a Magnaflow or Flowmaster muffler hurt the car and or void the warranty? Should I just forget the whole idea instead?
  • quickr1
    quickr1 Posts: 414
    i don't think just a cat back exhaust would void the warranty. you should check out camaro5.com i bet that you would find the answer there. did you get a v6 or v8 camaro?
  • Upstatemax
    Upstatemax Posts: 2,798
    Is this for sound or power?
    If you're after power, don't waste money on a muffler. To see any real gains, you'll want to start at the headers and work your way back.
    A muffler alone should have zero impact on the warranty, but I would contact chevy to make certain.
  • If this is for sound, get a V-8. Otherwise stock is the way to go. :D
    He already has the car so a V-8 isn't an option. The mufflers you mentioned won't hurt the car, but it does give the dealer a leg up to refuse any warranty work associated with it. Your best bet is as along as the warranty is in place, keep it stock. A muffler isn't going to change any performance worthy of a mention anyway and a 6 that only sounds like an 8 is kinda lame in my book.
  • nguyendot
    nguyendot Posts: 3,594
    Magnaflow. I had a Cadillac CTS with the same 3.6L engine and did custom Magnaflow (x2) and an X pipe. The Xpipe removed the drone (which is weird) and made it sound amazing outside.
    https://www.youtube.com/watch?v=G3H1CEJYLC8
    Main Surround -
  • shawn474
    shawn474 Posts: 3,052
    Magnaflow; throaty and deep - not raspy at all. Catback will not void the warranty. In fact it is illegal for them to deny warranty claims. This is a good resource to read up on and learn - Magnuson-Moss Warranty Act
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • nguyendot
    It will void the warranty on anything behind the cat, but cannot void anything on the rest of the car unless it a) actually caused the warranty issue and b) they can prove it.
    Main Surround -
  • shawn474
    Right; the pipes, new muffler and hangers wont be covered by the vehicles bumper to bumper warranty obviously. But everything else is still covered.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • quickr1
    quickr1 Posts: 414
    I'm leaving mine stock until the warranty is up. after the warranty i want to get headers all the way back and also a cam.
  • charley95
    charley95 Posts: 908
    If you want it to sound like a zipperhead car,go for it.
  • I would leave it alone. Changing the exhaust will only highlight the fact that the car is a v6. It's like your dating Klohe Kardashian, which is all well and good, nothing wrong with that, but trying to make her look more like Kim will only show that you think of her as being inadequate. As hard as Klohe may try she'll never be a Kim or even a Kourtney.
  • Msabot1
    Msabot1 Posts: 2,098
    Those gals have nothing on a 1970 Z28 350...Muncie 4 spd.....finest Camaro ever built.....
