Sound Valves VTA-70 Tube Amp
KLapinas
Excellent Sound Valves VTA-70 push-pull tube amp in very good condition. 35 watts per side, easy front bias using lights, rear gold RCA inputs, a modern version of the venerable Dynaco ST-70 using modern boards and solid state rectification and much larger power supply caps than the original. These do not come up often and is a great way to get into tubes without robbing a bank. Thanks for looking.
In Great Condition and sounds amazing
Asking $600
• 35W RMS Class AB
• 15W RMS Class A
• Frequency Response: 10-50,000Hz
• THD: <.25% @ 1000Hz, <.7% 20-20,000Hz
• Hum & Noise: Inaudible, less than -85db below rated power unweighted.
• Sensitivity: 1.3V RMS for maximum output power
• Power Consumption: 190 watts, 120 Volts, 50/60Hz (Capable of 220V)
• Tubes: (2) 6GH8A Gain Stage, (4) EL34 Electro-Harmonix Output• Size: 13"W x 10.5"D x 7"H
• Weight: 32Lbs
Asking $600
• 35W RMS Class AB
• 15W RMS Class A
• Weight: 32Lbs
Price reduced $550
Is that a relocated power switch on the front?HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yes, the original owner put it on the front because of where he had the amp.
Thanks Carl. How are the Classics doing?
Bump
$525
Price reduced $500
Bump
SOLD
