Nakamichi 730 reciever
pumpkinman
in Electronics
Picked up a Nakamichi 730 today at thrift shop. The Nakamichi 730 Receiver was manufactured between 1978 and 1981 MSRP $1400.
Has anyone here at PF ever owned one and if so what did you think of it ??
Tuning range: FM
Power output: 105 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 30kHz
Total harmonic distortion: 0.02%
Damping factor: 100
Input sensitivity: 2mV (MM), 100mV (line)
Signal to noise ratio: 83dB (MM), 94dB (line)
Channel separation: 70dB (MM), 70dB (line)
Output: 100mV (line), 1V (Pre out)
Dimensions: 500 x 90 x 370mm
Weight: 17.2kg
Year: 1978
Because I am The Pumpkinking
Sweet looking unit-with tons of power
nice find. How does it sound & what did you hook it to ? Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Right now they're hooked to my 3.1 TL's and a Kenwood KD-770D w/ an Ortofon X5-MC cartridge.
I don't know if the sound will change down the road. I don't know when it was last played.
The sound is definitely on the warm side.Post edited by pumpkinman on
