? About Phono Ground Screw
boston1450
in Electronics
Got a Denon DRA435r & noticed the phono screw was missing. If i find a screw to fit the hole will that be good enough-or-is it need to be connected to something on inside of unit also. First time ive came across this - missing the phono ground screw. Any advice would be helpful TIA - Randy
Going to use this as a pre/amp tuner for the Denon POA2200 so im excited to be hooking it up
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Thanks. I have a screw that may fit. I will try it tomorrow. That site has a nice looking ground thingy. If the screw thing doesnt work i will go that route. ThanksRandy-Maine
by David WMG
Got the screw in & hooked it up after work. The thought of using this as a preamp is being thrown out the window. Got a Denon pra1200 preamp comingRandy-Maine
by David WMG
