Squeezebox Touch/Logitech Media Server
I have had this config for a while and didn't invest much time in discovering it but put a few minutes into it today as I was doing windows updates (ok more like an hour)....
As anyone who has used the combination of the 2 has discovered it's an ok media server/gui and lets you play your digital content on your system adequately.
All am all about simple and after a day of doing customer system reviews and requirements documents I don't want to (can't) learn to many things during my relaxation time.
I installed a chrome extension called "Mini Squeezebox Control" and it helps me navigate the Squeezebox Touch nicely with albeit a tad on the spartan side.
Anybody with a Touch/LM Server running and how do you control it?
Garage | Polk Monitor 5B's
  • polk500
    polk500 Posts: 1,171
    Hello,
    Try the squeeze touch app on iTunes it's free, I use Ipeng cost a few dollars but worth it.
    Cheers
    Roger
  • coolsax
    coolsax Posts: 1,826
    i use the squeeze touch app. I think it is more effective an app on my iphone than it is on my Ipad sadly. Considering it is not a supported device any more by Logitech I have thought about switching it out off and on. Blue sound from the makers of NAD and PSB has caught my attention but haven't had a chance to try it yet.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • zane77
    zane77 Posts: 1,696
    I use Ipeng and it works pretty well.
    Two Channel
  • nspindel
    nspindel Posts: 5,343
    iPeng is still supported by it's author, I use it constantly. One of the best things about iPeng is that you can pay an extra $5, and use it as a player. So basically your iPhone becomes a Squeezebox, and can play anything your Squeezebox can. Then you can open a port on your router and forward it to your LM Server, and then you can use your phone as a streaming Squeezebox player outside of your house. I then play the phone through the aux input in my car, and I have a streaming Squeezebox on wheels!
    EndersShadow Posts: 17,716
    nspindel wrote: »
    Dumb question but how does it handle high rez files (24/192, etc) when playing through your phone? And I am assuming the streaming data counts against your plan, so how much data does your cell plan have?
  • Mikey081057
    Mikey081057 Posts: 7,127
    I am android and can't find the player version they talk about on the store. I am ok with what I am using, as it know have the media player working with all of my devices... just trying to see if there is anything better for CHROME...
  • PrazVT
    PrazVT Posts: 1,607
    nspindel wrote: »
    Hi-Res files get down-sampled to 16/44. If you go to 'More Info' in Squeeze Commander (or whatever app you're using in Android), it'll show something like 'Converted to 705kbps FLAC..'.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
