Dolby Atmos 5.1.x Speaker Setup and Suggestions
invinciblesingh
in Speakers
Hi Polk Community,
I have just started to build my HT setup, so to be future proof I thinking of going straight to 5.1.2 atmos. May be go to 5.1.4
I have dedicated 12w x 17l x 9h room.
Room would be mainly used for watching action movies.
I already have
Fronts: Polk RtiA9s
Amp/receiver: Emotiva XPA-2 and Onkyo 838.
Center = CSI A4 or A6 ??
WAS considering FxiA6 for rear surrounds, but as Fxi's are bipole/dipole, and i read that only direct speakers should be used with Atmos, which other speakers should use for
Rear Surrounds - I don't want too deep/obtrusive speakers - ??
Ceiling - Which would be better choice for atmos 70-Rt/90-Rt or 80F/X-RT ??
Any help is appreciated.
I already have
Fronts: Polk RtiA9s
Csia6 definitely.
And probably the rtia3/a1 for rear if you want to stay in the same product line.
As for deep/obtrusive speakers, I am not sure
As I would think they would carry a heavier load versus the ceilings.
Good setup by the way. Excellent starting point.
Good luck!!Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen" -
That AVR is a good choice I got the same one , go with the A6 for your center. I Have the A3s for rears and surrounds. I would think the 70 or 90 RTs for the ceiling would do just fine.Home Theater
I guess if you can go ceiling speakers that might be the desired approach.
However, I bet more will offer pods to site on top of your current speakers...like what KEF is offering here: http://www.kef.com/uploads/images/en/r/what_is_atmos.htm
Would like to hear Atmos...but even before that, I would like to see what front Height and Wide would actually sound like in my system. Need the room for it first.
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
I have a similar setup. I would definitely recommend the A6 over the A4. For ceiling speakers, I bought 4 of the 90RT but was having second thoughts on whether I should have bought the 80fx-RT. I haven't installed them yet so my opinion is not based on actual experience.My system:
http://www.blu-ray.com/community/gallery.php?member=ahmedreda
RTI A9/CSI A6/RTI A5
Subs: 3xRythmik Audio FV15HP
Denon 4311CI/Emotiva XPA-2/Emotiva XPA-5
BenQ W6000/W7000 projectors/130" 16:9 screen
Playstation 3/WDTV Live/Roku 2 XS /Apple TV/Tivo HD[/SIZE] -
Thanks everyone for their inputs.
I got the A6 for center, so that blends in perfect.I have a similar setup. I would definitely recommend the A6 over the A4. For ceiling speakers, I bought 4 of the 90RT but was having second thoughts on whether I should have bought the 80fx-RT. I haven't installed them yet so my opinion is not based on actual experience.
ahmed: why do you think 80fx-rt may be better than 90rt. My main goal is dolby atmos. Also which ones you use for surrounds.?
I don't know for sure it will be better.. I read that top speakers are preferred to have wide dispersion to avoid localization and I assume the 80fx will have a wider dispersion than the 90-rt. The 90-RT is an overall more capable speaker but I wonder if the extra extension / output is really needed in this case.
I use 4x RTI A5s for surrounds.invinciblesingh wrote: »Thanks everyone for their inputs.
ahmed: why do you think 80fx-rt may be better than 90rt. My main goal is dolby atmos. Also which ones you use for surrounds.?My system:
