Found my center (CS1000P) but critters found it first!!
WLDock
WLDock Posts: 3,073
edited September 2014 in Speakers
Well, been looking for a little bit but I finally found a Rosewood CS1000P center channel. It arrived a little more rough than I had hoped but it's not too bad. Man is it BIG...not that I didn't know the size, but lifting it and seeing it in person really SHOCKED the family, LOL!
Here is it with the CS400i on top:
Like all used speakers I clean them up...even pull them apart before I do anything with them. A couple of times (RT800i, CS4000i) I found waste, etc from little critters like chipmunks, girbals, etc. living inside. Sure enough, I pulled the drivers out of this unit and here we go again!
Disgusting! So, I got her all vacuumed, washed, disinfected, waxed, etc and set up. I had to balance it on my make shift stand witch is now too small. I plan to make a custom one for it with the height and angle that I need. Also my AVR is sitting on the floor as it gets too hot to go in the rack. I will sit it on a slab of granite or something under the stand when I get it done.
Here it is added to the system in my too small room. I had to stuff two couches, a love seat, and a wing back in it here. Moved from a 1900 Sq ft w/living, and family rooms to a 1400 Sq ft w/ just a smaller family room. i removed the grills for the picture;
Well, I calibrated the system and the dynamic range seems to have improved with this cal. I did turn the levels up all around. At first voices from the center sounded congested and raspy compared to the CS400i. However, turning down the bass level helped to clear this up. It sounds good but not as huge of a difference from what I can tell just yet. However, I did fire up a FOCAL demo disc with just the center playing and it was pretty full sounding....pretty cool!
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • vmaxer
    vmaxer Posts: 5,124
    I have one in black and love it. I also have the CS 400i, it is good but no match for it.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Mystery
    Mystery Posts: 2,546
    What was in there?
    Rats?
  • WLDock
    WLDock Posts: 3,073
    Looks like some small rodent. I got the shop vac and my disinfectant spray out. I spayed the entire inside, outside, and port. From the pictures the guy sent...it looks like it might have been stored in a garbage. The same was true with the past speakers I had.
    So, check the insie of your speakers if you purchase them used....speciay ifthe wee stored outsde.
  • WLDock
    WLDock Posts: 3,073
    What the heck did I just type? :p
  • Mystery
    You typed that the speaker was in the garbage so obviously critters got to it. :wink:
  • WLDock
    WLDock Posts: 3,073
    Yeah, what the hell? Its like I was drinking or something....there are a lot of broken and misspelled words. Should have been "garage."
