NHT X1 Crossover
zingo
I upgrade to a pre/pro which has subwoofer control, so I don't need this awesome external unit anymore.
The X-1 is an active, electronic crossover designed for home audio subwoofers, and can mate to any amplifier. The X-1 is stereo/mono switchable and has a feature set designed to shape bass frequencies to work in almost any room.
Control is the key word for the X-1. It manages both front L & R line inputs (2 channel electronic crossover) and LFE signals with independent control for mixing. It has 3 settings for high passing to satellites, and fully adjustable low pass and phase controls. In addition you can adjust boundary eq from +6 to -6dB. The X
-1 is one of the most affordable, flexible, fully featured active crossovers available on Earth.
Crossover Frequency - 50Hz, 80Hz, 110Hz high pass, 50Hz-140Hz adjustable low-pass filter
Crossover Slopes - 12dB/octave high pass, 12dB/octave low pass
Phase - 0/180 degrees switch, 0-90 degrees variable
Input Connectors - XLR, RCA
Output Connectors - XLR, RCA
Dimensions - 2.125"H x 17"W x 11.5"D
Weight - 9 lbs.
Controls - Gain, LFE Gain, Phase, LP, HP, Boundary (+/-6dB), Stereo/Mono, Trigger mode
Weight - 9 lbs.
Comes with the original NHT power supply!
$120 plus actual shipping double boxed. -
Got it thanks. Did you get my response?
