Blue font is much nicer
Just got back from Maryland's Eastern Shore, and am accessing the forum with my iPad versus the iPhone, and I see after weeks of people complaining about the red font it has been changed to blue. Plus the text on the right is now black.
It looks much better. While better late than never applies here, it still took way to long to fix that mistake.
Thank you.
  • vmaxer
    vmaxer Posts: 5,117
    You are correct, much better.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Still intensely dislike the 'narrow' format and the clutter of countless icons...
  • I think the blue font is a great improvement that has allowed me to appreciate some of the new format's benefits.
    Let's hope the good folks a Polk keep working on continuously improving the new Forum.
  • StevieB
    StevieB Posts: 256
    edited September 2014
    Don't know if anyone has posted, enlarge the forum you are in to fit the screen and it pushes the categories to the bottom. Much less clutter.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
