Upgrade for Monitor 4s?
Lukey2014
I have a nice pair of Monitor 4s but I'm not really pleased with the sound of them. I use them in my bedroom mostly for listening to public radio with a Yamaha CR400 receiver and a Sony tuner.
Are there tweeters I can put in that aren't real expensive that would improve the sound? Mine have the triangle shaped covers over them.
Can you give me some ideas on better speakers for my bedroom? I'd like a bookshelf speakers, not too big with no more than a 6.5" woofer. I think I prefer non ported.
I was thinking of some Boston A40s or Infinity Sterling 2001s, which are both non ported. I was also looking at Fluance SX-6 and SV-10S, Micca, Pioneer, and a few others.
If you want to stick with Polks. Go with Monitor 5's with Peerless tweeters OR S6's would do well & you can thank me later. The Monitor's (any 5jr jr+ 5's or 7's) match Yamaha's quite well & can be had reasonable for a nice set. Ive got a CR-620 with S6's & love them. Good luck with your search
EDIT. As far as upgrading tweeter. Spend the coin & get a better speaker VS cost of tweets on that model-if its a series2 . That would be my opinionRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
You can try Part-express vifa tweeters.
http://www.parts-express.com/vifa-bc25sc06-04-1-textile-dome-tweeter--264-1028
I had KEF Chorale III and it was very nice for the size.
Also, JBL 2500/2600 are good options.
If you do get small Polks with peerless, make sure to get a sub as well as they just bite without a sub.
