The walkman is back...
gce
gce Posts: 2,158
Anaheim Hills CA,
  • hochpt21
    hochpt21 Posts: 5,423
    The Pono and now this...very interesting the way the world is headed.
    mhardy6647 Posts: 35,193
    When the reel to reel Lugman comes out -- I'll be on the preorder list...
  • brgman
    brgman Posts: 2,859
    When you have a Bluetooth player and send say 96/24 to the server,in this case the car radio,what does the radio do to that signal?
    Is it a pass through technology or is it processed in some way?
    I’M OFFENDED!!!!
  • This might be a great replacement for ipod classics now that they are being discontinued. Two of mine just got stolen from me the other day. Not sure if I was going to buy two more or go another route. These SOUND promising.
    Are there any car stereos that are simply media players with hdd or ssd/flash drives? Sure should be.
    KEF Q50 mains, M&K center, Boston Acoustics surround, Marantz SR6007 pre, Emotiva UPA-700, Pioneer DV-46AV, Samsung BD-j7500, Sunfire HRS12 subwoofer
    pitdogg2 Posts: 27,213
    Sony needs to get their head out of their lower end...lets see bring out hi-rez SACD then get out of SACD. Which is it going to be Sony support hi-rez or not you can't have it both ways...
  • Emlyn
    Emlyn Posts: 4,804
    Looks like a good idea from Sony to fill a gap in the market. Astell & Kern does make a portable player that will store and play back both high resolution PCM and DSD, but their cheapest unit costs $799. It looks like the Sony isn't set up to do DSD, but I'm wondering if a firmware upgrade might enable it in future.
    I am attracted by the storage capacity on the Sony unit as I have an iPod Classic with around 140GB of 256K MP3s on it. I have had two of the 120GB versions have fatal hard drive failures after around 2 years of use. Would be nice to have something that also plays back FLAC files. Looks like the cost will be $299, but a 128GB microSD add on memory card would add another $100.
  • PrazVT
    PrazVT Posts: 1,607
    I recently bought a FiiO X5 (mini review has been a pending item for it for some time) DAP, and while it's a bit chunky compared to my iPod 160GB I love it. 24/192 FLAC support + DSD support recently. At the moment, I have two 128GB microSD cards in it, but when larger ones come out I should be able to upgrade. I actually use it in my car alot (has a separate line out) and SQ is very neutral. Software has been stable as well.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • BlueFox
    BlueFox Posts: 15,250
    I'm not sure what you mean here. Sony is releasing their DSD files to download.
