wireless router recommendation
WagnerRC
Looking for advice for the best wireless router that can give some decent range. Using a dlink dir 825 and the range sucks.
Thanks for any information. My property is less than a 1/4 acre flat.
What is your operating system and budget??
I use an imac and windows both. no budget, i just want good reliable coverage. Thanks
Check out ASUS...RTAC68U....for about two bills...just about the best out there..excellent coverage area and lots of business features......
Linksys WRT1900AC
What modem do you have?
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I have one also and is great router..... I like the Asus app for android. I have a NAS connected to the router with a lot of music and I can stream to my phone, from anywhere.
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
I have an arris modem from comcast
Do you know which model? If you're renting, it's honestly cheaper to buy if you're going to have service from them for the next couple of years.
I usually buy the latest and greatest Motorola Surfboard modem, and have had good luck with those in the past. I haven't purchased a router in quite a while, but am pleased with my Linksys.
"It's like a koala bear crapped a rainbow in my brain!" -
I was blowing thru Linksys routers, every couple of years. I spent some $$$ on a Netgear, has some sort of extended warranty, 7 years, IIRC.
When it comes to routers, ya gotta spend some $$$.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
the cisco/linksys routers were garbage... the new belkin/ linksys are very good.My New Year's resolution is 3840 × 2160
I went ahead and ordered the asus for 200.00 Thanks for the information.
I think that you will find the performance and features worth every penny...this is a very reliable piece of gear...let us know how it does for you.
Thank you. I will
Asus all the way.Shoot the jumper.....................BALLIN.............!!!!!
Just updated mine and was going back and forth between the Asus N66u and the Netgear Nighthawk. Went with the Netgear because of the larger processor. So far works much better then the old dlink I had.
I'm also having problems since we switched over to TW internet. Man they S'u'c'k!
I've heard the Asus RTN66U whatever, the older model is great for less than 139 if you can find it? I've also heard you should NOT spend more than 149 on any router unless you're running the "latest and greatest" of every tech gadget and PC, etc. It's a waste of money over that price point.
The newer Asus 68, according to a tech friend of mine, does not perform as well range wise as the 66.
The router works great. Easy install, great coverage and works perfect. Thanks again for the help.
Glad it worked out for you...I incorporate this gear into my clients systems...the failure rate is almost non existent.....great performance and user friendly to boot!
I've been really happy with my 3TB Time Capsule, it's the latest gen and has been rock solid since the day I bought it.
