Polk Monitor 70's tweeters
novem
Call Polk's Customer Service
1 (866) 764-1801
I am sure they can help.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
I have a pair of Monitor 50 tweeters. They could be the same thing...I had them send to me when I was having issues with my Monitor 50s, but it turned out to be the amp.
Never even opened the box.
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
$45 If I recall correctly from Polk when I called about my buddy's m70's awhile back.Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen" -
lsi 9's -
He probably blew them! Monitor series tweeters are fairly easy to take out if you clip your amp even a little. The Rti lines have a heat sink behind them that helps them handle things better.
Not that the Ms are bad, you just can't CRANK a cheap amp with them and do anything but lose them. I have had mine plenty loud with a power amp behind them and have "never" damaged anything!
To OP, you shouldn't have any problem getting replacement tweeters from Polk but you may want to also check to see if you haven't damaged the crossovers?
