Polk 5JR
oldrocker
I got a set of these speakers today, there is a small corner scratch spot, more like a tiny circle. The veneer is really dark. My question is, can a person use or has anyone ever used a dark brown colored "sharpie" marker to cover scratches on the veneer?
Its kind of hard to see but the top left corner has a spot. -
I think they actually make pens in those type colors. Walmart sells them in the hardware section."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Thanks....
Yeah, get the pens that are specially made for touching up furniture. Sharpies tend to leave a sheen you probably will notice, even from a distance. If not at WM, the pens can be found at Home Depot, Lowe's, etc. For dark cab's like those, I think I've used a color called "Dark Mahogany" and it worked like a charm.
Dark Mahogany & dry erase markers. Thanks Guys....
