Onkyo 797 Sub Out
fknfsm
Need a little help! Does anyone know if the pre amp sub out on the Onkyo 797 is filtered or not. Manual doesn't say. Being in the pre amp section, I would assume it's not but since it's labeled as "sub out", I'm not so sure. I'm trying to determine the best way to hook it up to my PSW350. (LFE or Line input)
Thanks,
Dave
Thanks,
Dave
Post edited by fknfsm on
I'm about 99.5% sure that the "Sub Out" jack passes a filtered signal. I don't have any experience with that receiver, and in my minimal research, I haven't been able to find out for sure.
Since the 797 is a THX certified receiver, the bass management, and crossover frequency should conform the the THX standard of 80 Hz.
If you haven't done so already, you might check the specifications section of the manual and see if it lists a subwoofer, or low pass crossover frequency.
Jason
P.S. Welcome to the forum. I notice you're from Arkansas also. What city? Ft. Smith is my guess
i was wondering the same thing about my onkyo 777, so i emailed onkyo because the manual doesnt say and they replied back with an answer of
yes it is filtered and at 80 hz
Speakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
Hi Jcaut,
Good guess, I am from Ft. Smith
Thanks for the reply! -
yes it is that is what i use for my setup and i have the 787
