More Opinions anyone?
Tmeleo
Tmeleo Posts: 2
edited December 2001 in Technical/Setup
Thanks all for your advice regarding RT vs. RT i series speaker configurations. Here's what I'm thinking...I live in a tiny one bedroom in Manhattan so space and price is an issue.
I'm thinking of using my current RT35's as the fronts, buying the CS175i as a center, and buying RT10's as the rear. From what you all said, I'm pretty sure all these speakers use a silk dome tweeter...am I correct?
You guys think this'll cut it? I'm basically looking to fill a small space with a rich sound that blends together evenly throughout the room. Thanks again
Post edited by Tmeleo on
  • jcaut
    jcaut Posts: 1,849
    Personally, I think that sounds like a fine configuration for a small room. The RT35's will do nicely as fronts, R10's can be had for, like $100 now, and it should be easy to find a used (or new in the box) CS175i for a good price. In fact, I've got a barely used one I might sell...
    You could even add an inexpensive sub like a PSW250 (which is also easily found used--I've got one of those, too) to round out the system.
    Jason
  • ntculenuff
    ntculenuff Posts: 1,146
    if you do get a sub just be careful subs tend to upset nieghbors in apartment living ( i am assuming you live in an apt) if not get the sub and bass away :D
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
