changed my rack
leftwinger57
leftwinger57 Posts: 2,917
edited August 2014 in Electronics
If you remeber I had what amounted to a self made contempary audio rack that I added shelves to. I saw an ad this morning in C/L and it was for a black lacquer style audio rack for $20. The thing is big and if the pix shows the tt has enough room for the cover to raise all the way. Everything is back together and thanks to me marking all my cables and using bananas when I can makes reinstalling a lot easier. Of course nothing changed sound wise but it sure looks better than my old dust collector. I think it looks good and it came w/ casters already fastened to the base for ease of wiring and is just high enough where I can still get to my house alarm keypad behind it. Oh, there was an ad yesterday for Jensen #6 speakers for free but all 8'' and 15'' surrounds were totally rotted. I was going to give it a try and asked a forumite here if it was worth it and he said stay away they are just big and not all that impressive and what you have already is better. They were gone by the time I tried to say no.....
http://i42.photobucket.com/albums/e344/leftwinger57leftwinger/DSCN05253_zpsc1a49ff3.jpg
  • gce
    gce Posts: 2,158
    edited August 2014
    Very clean setup... like it!
    Anaheim Hills CA,
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2014
    It appears to be a fully inclosed rack, not the best idea! Especiall for that 555 it should have plenty of air.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • leftwinger57
    edited August 2014
    It came w/a cardboard backer which I chose not to install for that reason.I've been running it all day and the Adcom is still running as cool to the touch as ever. Thanks for the concern but it's not an issue. If anything the Yamaha RX-V665 needs more air than any device I have and also has been ok all day.
  • soundfreak1
    edited August 2014
    Thats a good idea ( removing the back) heat build up can be an issue.but that should take care of it.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • boston1450
    boston1450 Posts: 7,700
    edited August 2014
    Looks very nice. Big plus to be able to open tt cover & have enough room. That seems to be a big problem with racks
  • leftwinger57
    edited August 2014
    Thanks, it looks wacky w/ that space but it's exactly enough for the cover to open fully. What does anyone with lacquer furniture use to clean the stuff ? Black is nice when clean but in the light you see every smudge and finger print.
