In wall installation question
JamesK
Hello All,
Quick question. I am installing a pair of LC65is (surrounds in the main room) and a pair of RC60is (in the kitchen).
My question is - do I need to box in the area behind these speakers or should I simply leave insulation lying flush against the back of these units ?
Any problems with the components on the backs of these speakers being in contact with the wall insulation - either the paper or fiberglass side...
James
James
Post edited by JamesK on
When I installed my RC60i's I did not box in. I was under the impression that they used the wall area and the insulation would reduce standing waves. I have had no problems at all. They have a very nice clean sound, but limited bass. I hope this helps, I'm sure that if you called Polk CS they could elaborate.
GregAVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One -
Mine are not boxed. No complaints. Would they sound better boxed? Maybe.
Regards,
PolkThug -
I've gone both ways, with insulation and without. I prefer the sound with insulation behind the speaker. I put the insulation side to the speaker. The paper is flamable, the insulation is not.
You could try these:
http://www.crutchfield.com/S-4C3FxfOHsh1/cgi-bin/ProdView.asp?s=0&c=1&g=110800&I=188SC1&o=m&a=0&cc=01&avf=N
It is a fairly low cost investment.
Everybody is going to have a different perception of how well they sound. In-walls can sound really good. Different construction factors will influence it the most. I love the idea of in-walls, and will probably do it somewhere in the house, at some point.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
