Pre amp remotes.
xjghost
xjghost Posts: 1,115
edited August 2014 in 2 Channel Audio
More of a rant then anything with a question. I have been scouring fleBay and Cl for some newer gear to replace my aging Kenwood Receiver. Stumbled across a nice looking Carver CT-24 for $69.99. I figure why not see what happens. Bid $70 and forget about it. Figured I'd never win because these things generally go for a lot more over there. Also came across a NAD 1600 for $49.99... Oh heck why not. Bid $50 and forget about it. So now I have two pre's to play with. Both working and both in decent shape. Went looking for a remote. WOW! Really? The only NAD remote is this one on ebay for $49.99 and it has no cover!!!!
http://www.ebay.com/itm/NAD-System-Remote-Control-Monitor-Series-Receiver-Pre-Amp-Stereo-NoBATTERY-COVER-/181487940314?pt=US_Remote_Controls&hash=item2a418632da
I did find these:
http://www.amazon.com/Replacement-Control-NAD7100-NAD1600-NAD1700/dp/B00A82O72W
http://www.amazon.com/CARVER-Replacement-Remote-Control-TDR2400/dp/B00ARM97PU
I guess I'm a cheap **** but no way I'm paying that much for a remote when I have close to that in the gear itself. So I see universal remotes in walmart and best buy all the time. I have one for the TV stuff but I notice they don't control audio equipment. Is the only option finding an original or these ready remotes? On a side note..... I'm now looking for some 2 channel amps on eBay, here, and CL.
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
Post edited by xjghost on
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited August 2014
    try this guy
    http://www.remotes.com/?gclid=CLfDqav8ksACFQto7AodCWUAkQ
    or get a used logitech harmony
    Garage | Polk Monitor 5B's
  • xjghost
    edited August 2014
    try this guy
    Bingo! That is what I was looking for! Nice site too!
    http://support.myharmony.com/en/compatibility?utm_source=logitech.com&utm_medium=promo&utm_content=pdp%20-%20footer&utm_campaign=compatibility%20lookup&WT.ac=ps|11364|lphmcomp
    I knew they had to exist but could not find them. I knew someone here could help! Thanks!
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2014
    Hope in this case im wrong but.... I have found most ( "all"in my case) non- original remotes for pre especialy processors will not run all functions ( usually the most important ones) the price they charge for the correct remotes is because they have them and you need them! Been there! I always search the remote cost and availabilty first before bidding. Past expierance has taught me this. On a lighter note
    ... I know where all those missing remotes go!!! They are with all those socks that go missing from the dryer!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    billbillw Posts: 7,824
    edited August 2014
    Find a different universal remote. The good ones have codes for most of the common equipment and are much cheaper than Harmony. I have used a couple of URC-R6 remotes, bought used cheap off Ebay. They worked great. Sony also made a few cheap ones that had a pretty extensive database. One4All also had quite a few inexpensive remotes with a good database.
  • xjghost
    Picked up a Logitech Harmony 650 and am happy with it. For $35 delivered I can adjust the volume of the Carver from the exercise bike or the bed. Which is what I wanted. It doesn't work perfect but then again I don't know what I'm doing. Thanks for the suggestion. Going to eventually try it on other equipment and see how it works with them.
  • voltz
    voltz Posts: 5,384
    I have a 650 & 750 and they are great. I have 1 for living room & 1 for the bedroom.
