Need DAC Recommendation
cmy330go
cmy330go Posts: 2,341
edited February 2004 in 2 Channel Audio
I am in the process of setting up a dedicated two channel rig. So far I have a pair of LSi9s, a Music Hall MMF-7 running through a Parasound PPH-100 phono preamp, a basic single disc Sony CD player. All of this is currently running on my older Marantz SR5000 A/V reciever until my Parasound Halo system gets here. At which time I would like to add a DAC for cd listening.
This raises a couple questions. First of all what do you guys recommend for a good budget DAC?
And also is it ok to continue using the Sony CD player as a transport? I have heard a few people suggest that a standard cd player with optical out can make a rather decent transport. Do you all agree?
Any help as always is much appreciated.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • steveinaz
    steveinaz Posts: 19,546
    Although digital "coax" out is preferred, your Sony will do fine thru fiber. Bel Canto makes a wonderful DAC (Digital design DAC2), but VERY pricey ($1,200, I think). Someone else may no good stuff at a lesser price, and used is always an option...
  • tonyv1
    tonyv1 Posts: 365
    I use an MSB Link DAC III with the optional 24/132 upsampling installed. The basic MSB Link DAC III goes for $499 and the upsampling adds another $199. I use a Rotel RCD-951 as the transport with a Cardas coaxial cable. The MSB has both coax and optical inputs that automatically switches to the active signal.
  • organ
    organ Posts: 4,969
    Used ones are much cheaper. I just purchased one from Zane in the flea market. www.audiogon.com have some good ones cheap.
    Maurice
  • shack
    shack Posts: 11,154
    I've heard some good things about the Channel Islands Audio VDA•1 for $349.
    Here is their web site: http://www.ciaudio.com/
  • HBombToo
    HBombToo Posts: 5,256
    Tony how do you like your MSB? They make some really nice products and soon I'm gonna grab the mvc-1.
    HBomb
    ***WAREMTAE***
  • tonyv1
    tonyv1 Posts: 365
    I like it so much that I don't miss the HDCD feature on the Rotel. The upsampler gave better top end extension without sounding edgy, grainy or harsh. Supposely using the aftermarket power supply (from MSB for $399) adds more authority to the bottom end. I rigged my DAC to be able to switch between 24/96 and 24/132 (it sucks to remove the cover just to swap jumpers) just incase the 24/132 was too shrill. It's switched to 24/132 full time.
  • cmy330go
    WOW!! Thanks for all the great info so far. This should give me plenty to research.
    In regards to the upsampler on the MSB......How much of a difference do you here between the two settings, and in what ways is it most noticeable?
    Oh and does anyone know anything about one called "DAC in a Box"???? I think that was the name I heard. I may just be crazy though.
    Thanks again guys. Keep it comin':)
    HT
    2 CH
  • gidrah
    gidrah Posts: 3,049
    Yep. I've got a "DAC in the Box". To be honest with you I haven't used it too much. I just purchased a new transport and expect that to change in the near future.
    Make it Funky! :)
  • organ
    organ Posts: 4,969
    Cmy,
    My DAC in the box is on the way. It should arrive proabably by next week. I'll let you know how it sounds when it's here. I also bought a "jitter buster" DTI unit by Audio Alchemy from audiogon for $95. Goes before the DAC to reduce jitter.
    Maurice
  • cmy330go
    ok I just saw this on audiogon.com "Perpetual Technologies P3A DAC"
    Does anyone have any experience or opinion on this one? Seems new retail is $799 and there is one with 22 hrs left on the auction that is at around $200.
    Any thoughts?
    HT
    2 CH
