Easy suggestions for wire management
Pycroft
Hi all,
I just bought a new Salamander 702 AV rack. I am excited to get my gear up and running again. I have everything unplugged, and was just thinking that it's usually a mess behind the unit. I don't want to go crazy, but are there some easy, already lying around the house type things people use for wire management?
James
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
Zip ties or velcro strips.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
I'd love to see pictures of it done well. Is there any typical way to get the wires together within the rack? The Salamander 702 is a two-tier rack with a strange configuration. Thanks.
James2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
John Megadeth wrote: »Zip ties and mounting blocks.
Here's a shot from behind our media stand about two-thirds of the way completed:
Attachment not found.
Is it okay to coil AC lines? I know you can get noise from doing so in speaker cables, but I've never read anything about it concerning power cords. -
Even through you don't have them around the house, Monoprice velcro straps are cheap (61 cents for 6) and work well. They are what I usually use.
http://www.monoprice.com/Product?seq=1&format=2&p_id=5815&CAWELAID=1329452023&CAGPSPN=pla&gclid=Cj0KEQjwmayfBRDo25CR9un4hvEBEiQAv9fBbYtp20FNYK3dyUgqzyJdGm5Ec6guJDdwKkwQtAFVj_oaAsJy8P8HAQ -
Wow. Well-done. It doesn't matter how many ties I use, my rack looks like a bag of snakes exploded not matter what I do.Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103 -
Agree 100% and use zip ties and mounts. Good cable management can render a very quiet background to the music. Keep digital coax's clear of analog IC's, and power cables clear of everything.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
For Velcro ties use the kind that come in a roll of 50. Priced well under $10.
If you use plastic zip-ties, don't pull them too tight. Use a toe-nail clipper to cut the tail.
If you coil an AC cord, flatten the coil to make a bundle.
If you are running cords and cables from point A to point B.
Bundle all the AC cords together
Bundle all the interconnect cables together
Bundle all the speaker cables together
All the bundles should follow the same general path
A 2 foot separation of AC cords from the others is much more than enough. Think 6 to 12 inches.
