Turntable Stylus Question
boston1450
boston1450 Posts: 7,758
edited August 2014 in Electronics
Stylus with a brush that clips onto stylus. Ive had & seen these before & was wondering what they are called & where would you find them online to buy.. Do you use them-do they work for you ? Hunted some & came up with nothing except dustbug or something like that. TIA
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
  • boston1450
    edited August 2014
    Another question. I would like to upgrade my stylus on a Empire 2000Eiii & keep it at a budget of under 200.00 range OR do you think i should keep using the cheap stylus for now & upgrade my cart & stylus on Marantz 6300 when i can afford it ?
    Randy-Maine
    by David WMG
  • agfrost
    agfrost Posts: 2,474
    edited August 2014
    Some Stantons and Pickerings (others?) came with the brush integrated into the stylus. I recently bought a replacement Jico stylus for the Stanton 881S cartridge that came with a turntable I came into rather recently. It was not an inexpensive stylus, and it sounds very nice, but I had to remove the brush to make it so. Somehow the brush hinge was allowing a whining vibration to come through the speakers that was very evident in the silence between tracks on each album. If you use a NOS stylus that has a brush, I'm sure it wouldn't be an issue.
    The dust bug has its own arm, I believe. Helps with dust and perhaps static? I haven't used one, but I know SCompRacer uses one on his modded Lenco.
    Not sure about your Empire question. There are plenty of people who like Empire carts, but I don't have experience (although I do have a 999 S/EX that came on a turntable that I've never used; its stylus needs replacement). It appears that original replacements are available, here's one place: http://www.adelcom.net/EmpireStylus1.htm Depending on your budget, you may find that very reasonable or out of your league. If you've been able to hear the Empire in a fully working state and you like it, a replacement stylus would be a good bet. If it didn't float your boat, I'd recommend saving for something else.
    Edit: Poking around a bit I'm not sure that the linked stylus is NOS, so don't take my original thought as fact without doing some verification.
    Good luck!
    Jay
    Jay
  • gdb
    gdb Posts: 6,012
    edited August 2014
    The Shure M97xE cart. has an integral brush/stabilizer. Not a bad cart. and performs on par with much more expensive ones. (**** to mount, though) http://www.amazon.com/Shure-M97xE-High-Performance-Magnetic-Cartridge/dp/B00006I5SB/ref=sr_1_11?ie=UTF8&qid=1407472418&sr=8-11&keywords=audio+cartridge
  • boston1450
    edited August 2014
    Thanks for the info. Jay i have seen those ones with a roller (if thats what their called) you are correct about stylus brush causing problems with vibration. It seemed like the Pioneer was doing just that with a different stylus on it. Maybe i will pass on that thought..... For the Marantz 6300 i need to research more on Empire stylus. The cheap stylus seems to work good BUT was thinking i could get better performance with a better stylus for it. Seems the Empire is hard to get & may save for a change in cart/stylus upgrade.
    Randy-Maine
    by David WMG
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited August 2014
    Randy- you can score a new Shure M97 on Amazon for under $80 fairly often and or get the Orotfon 2M Red for $100. I like the bass of the Shure better myself. The 2M red has a crisper top end. I've used replacement empire needles from ebay and they work ok but have not searched for the higher end of the model lineup.
    With the Shure you can use it with the brush down or in the up position. It does clean the path a little and helps with playback of slightly warped records due to higher tracking force to a certain extent when in the down position. On another note, your tapes went out Wednesday via FedEx. I'll pm you tracking info in a bit.
  • boston1450
    edited August 2014
    Thanks .i will probably go that route maybe with a nice cart. I think it will be worth the coin. No need to send track # as long as you have them. Thanks looking forward to the JFK one :)
    Randy-Maine
    by David WMG
  • Montoya
    Montoya Posts: 506
    edited August 2014
    I got a 2m blue in the for sale section. bnib w/warranty
