Connector from Back plate to Crossover PCB
Sea
I am in the Dreadnaught group buy and am planning to make new back plates but would like to preserve the old. I have not taken the crossovers out again to look yet but, does anybody know the exact part number and or source for the connector on the PCB coming from the back plate?
I appreciate any information you might have. Thanks.
Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
Post edited by Sea on
Would need to know which SDA you're referring to, but have a look at this: http://www.gimpod.com/
That's the PCB that will work for most of the SDA line. Select the model you want to work on and then roll your pointer over the various components and it'll tell you what that is. Also, there's a list in the drop down menus.
BTW, these PCB's are the bomb - highly recommended for any Xover rebuilds."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Thanks I will check that out. I am referring to 1C's.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c -
Thank you Drumminman. Found it.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
