FYI - Frozen - Rusted Lug nuts
dee1949
dee1949 Posts: 1,425
edited August 2014 in The Clubhouse
...hours spent trying to remove without busting the lug. tried spays, standing on t-lug wrench with pipe extension. Broke a socket. Finally found it on youtube. Needed 2 do it twice...but it worked
https://www.youtube.com/watch?v=KwKHSvKfnHI
Enjoy
ps - not sure its safe to carry a torch in trunk. mine happened at home.
We should start a forum for "Helpfull Hints". Everybody has one.
Post edited by dee1949 on
  • Green '01
    Green '01 Posts: 60
    edited July 2014
    Sorry, double post.
  • Green '01
    Green '01 Posts: 60
    edited July 2014
    Good tip, thanks. Another option is Loctite Freeze and Release.
    Copied from Loctite's website:
    It's used to free rusted, corroded and seized parts. The shock-freezing effect will cool parts instantly down to -43 °C and cause microscopic cracks in the layer of rust. This allows the lubricating ingredients to wick directly into the rust by capillary action. Released parts remain lubricated and protected from corrosion.
    As long as you don't touch the parts, this may be safer than high heat from a torch when heat damage may be a concern (outboard engines, lower units, hydraulic cylinders, etc.)
  • gdb
    gdb Posts: 6,012
    edited July 2014
    The best and cheapest penetrant used by the auto restoration crowd is a 50/50 mix of acetone and automatic transmission fluid. It beat PB Blaster, Liquid Wrench and even Kroil by a wide margin in controlled tests. To buy a small amount of acetone, just get a bottle of nail polish remover, just make sure it's the acetone variety! (C;
  • halo71
    halo71 Posts: 4,632
    edited August 2014
    We use Nutcracker at work. Works great.
    --Gary--
  • Tornado Red
    Tornado Red Posts: 939
    edited August 2014
    At work I use Magic Wrench from Jet-Lube, very good stuff. But that may be Canada only, not sure about availability south of the border.
    tonyb Posts: 33,072
    edited August 2014
    halo71 wrote: »
    In my day, a "nutcracker" referred to something else. lol
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited August 2014
    When I was married, "nutcracker" referred to something else.
    A killer penetrating oil we use at work is called "Aero Kroil". A guy from Otis Elevator gave us a can once and that's all we use now. We were having a tough time breaking some pipe fittings free using 4' pipe wrenches with cheaters until we soaked the fittings with AeroKroil then ..... smooth as silk.
  • Jstas
    Jstas Posts: 14,985
    edited August 2014
    *cough*
    Expert Moron Extraordinaire
    pitdogg2 Posts: 27,072
    edited August 2014
    Aero Kroil is just the aerosol version of Kroil. I fist found it [kroil] when I started shooting. Problem is with Kroil is that it does so well at creeping through small places/orifices is that it literally creeps out of the can at all the joints in the can itself.
  • JimKellyfan
    JimKellyfan Posts: 696
    edited August 2014
    Power toolz
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • Jstas
    Jstas Posts: 14,985
    edited August 2014
    air toolz
    ftfy
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2014
    We used to use LPS rust inhibitor spray(can't remember how it was actually labeled as LPS made various spray lube products and cleaners for industries.) Sometimes we had to use an impact driver with a socket and hit it with a 4lb. sledge hammer. Usually that would free up anything unless the threads were so corroded they'd just snap off . Spraying area extensively and letting soak over night also brought great results without having to go to impact mode. The Loctite Freeze and Release sounds interesting as well as the acetone ATF mix.
  • brgman
    brgman Posts: 2,859
    edited August 2014
    As much as i love Loctite,the tests i did with some customers with the freeze spray when it came out were sadly disappointing.I was hoping for better results.
    Save your money.
    YMMV
    I’M OFFENDED!!!!
  • sucks2beme
    sucks2beme Posts: 5,686
    edited August 2014
    It doesn't rust hear in Dallas.
    Upstate New York- bleeding brakes was almost impossible.
    They always broke off. Down here, easy.
  • dee1949
    edited August 2014
    ...good input. i tried 2 different sprays and let them sit, then stood on a t-lug wrench with pipe that still would not give.. last resort before having it towed was the youtube version. saved me $80.00 tow fee. keep it in your library of fixes.
    ...also would recommend a 20" lug t-wrench in your trunk.
    ...never had a flat in this car and their was NO lug wrench.
    ...do new cars supply lug wrenches??
    ....it did have a scissor jack. never used.
  • brgman
    brgman Posts: 2,859
    edited August 2014
    I wonder what Old Bay would do?
    Thta would probably break that sucker loose and i know you've got some.
    I’M OFFENDED!!!!
  • halo71
    halo71 Posts: 4,632
    edited August 2014
    tonyb wrote: »
    I know what ya mean bro! My ex wife liked to use Nutbuster on me! ;)
    Although, I think if the OP would spray some black paint on dem ****.....they would be good to go! hehe
    --Gary--
  • dee1949
    edited August 2014
    ...lots of ole bay but would not WASTE it on my car. Evidently a relocated Marylander. This the season for crabs !! the GOOD kind.
  • brgman
    brgman Posts: 2,859
    edited August 2014
    dee1949 wrote: »
    Born and raised in Bawlmer.
    Oxygen and H2O and Old Bay is all i need to survive.
    I’M OFFENDED!!!!
  • dee1949
    edited August 2014
    ...be aware of scams from tire company's. Got a fair deal from Merchants Tire. While waiting for install they informed me that i needed a $440.00 front brake job. Never had a sign of brake problems. Beware. Will have it checked by my mechanic. They love to prey on the elderly.
    I ain't old even if i am retired.
  • sucks2beme
    edited August 2014
    dee1949 wrote: »
    My Mustang has no spare, jack, or lug wrench. Buying a set is on my radar.
    Everything seems to be going to those mini-compressors with goo.
