New SDA1c Amp Help
MrBuhl
MrBuhl Posts: 2,419
edited August 2014 in Vintage Speakers
Hi guys
Nabbed some really beautiful SDA1c yesterday. Not sure my Audire Model One will handle them (100wpc) and I found a deal on a Soundcraftsmen PCR800 which is 300wpc. Thoughts? Quality amp or not so much. I run my Harman Kardon AVR20II as a pre (and for rears) only so this really only has to handle the new 1c's in two-channel? He's been running it so it hasn't sat, and it has no issues.
Then on to the interconnect, dynamat, RDO's, Bh5 and such!
Many thanks!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Post edited by MrBuhl on
  • Schurkey
    Schurkey Posts: 2,122
    edited July 2014
    Any Soundcraftsman amp is due for service; it's old enough that the electrolytic caps should be replaced. Some folks really love 'em, I've never heard one.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited July 2014
    Schurkey wrote: »
    Thanks! Figured it will likely need caps or something too. Hoping for a good sounding amp in the process though.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • scubasteve4sq
    scubasteve4sq Posts: 72
    edited August 2014
    Crest pro lite amps are great price/performance ratio.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2014
    I think that unless you have an oversized room the Audire amp will be great. If it worked nicely for your 2bs, it will be fine for your 1Cs. I used an HK Citation 24 (same wpc) with my 1Cs and never felt the need for more power. The Model One wasn't overbuilt like their later Crescendo models, but it is no slouch either.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited August 2014
    Awesome - thanks - I guess I'll give it a try, it has never lacked for power with the 2b's and the room isn't huge either.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • Dennis Gardner
    edited August 2014
    Congrats on that 1C purchase! Anytime we can find large speakers in great condition in our own back yard it makes it all worth while.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited August 2014
    Thanks! BTW my buddy has an old rack mount 300wpc HK Citation 16, that thing is a brute! "rescued" it out of a roller rink I think. Love the old HK stuff.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
