Todays Freebie... Technics SL-QD33 TT
xjghost
xjghost Posts: 1,115
edited August 2014 in Electronics
Ok so as the title says I was given this TT by a friend. Technics SL-QD33. It's missing all the cords but looks decent.
Over look the junk on the table. So I see it uses what looks like a special cable with a seperate ground. Also a removable power cord. Neither of which came with said TT. So is this s good TT for my son's bedroom system? Sugesstions on where to get cords?
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
Post edited by xjghost on
  • boston1450
    boston1450 Posts: 7,758
    edited July 2014
    Technics are decent tables & that ground cord is around 9-15.00 (ebay model number & ground cord-plug Goodwill or Ebay) to your mailbox. If your looking to save it. Nice tt
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    edited July 2014
    With a good cartridge that DD Technics will rival most lower to lower mid-level tables from that period of time. And they're almost indestructible. There isn't much you can do to them short of dropping them to end their life.
    Quartz lock speed means you never have to worry about that. It was rumored that had TTs not gone out of phase for a while that Technics was considering upping the P-mount tech to their best tables and producing higher end cartridges. Alas, that did not happen. But they are among the MOST user friendly tables EVER made! There is literally "nothing" to do. No weight to set, no skating to correct for, no speed correction, and no need for a protractor, because the P-mount snaps into a universal socket at the correct distance, always!
    It's a great table, I keep a slightly higher model in reserve and a backup because I know it will never fail.
    The PERFECT entry table for your son!
    cnh
  • xjghost
    edited July 2014
    Wow I did not even realize that it didnt have pitch control till I read your post cnh. Even more excited about this for him. Come to think of it that power cord does resemble the cords of the boom box era! I probably have on laying around. RCA's are easy enough. I did find this with a quick google.
    http://www.turntableneedles.com/SJPB7M-Technics-Type-Turntable-Ground-Wire--Improved_p_3819.html
    I could build that If I can find that shielded round part that plugs into the TT. Radio Shack? Then again for $9 I coudl just get it delivered...... I also took a closer look adn it has a SURE Cartridge.
    mhardy6647 Posts: 35,374
    edited August 2014
    Those later Technics tts don't have much of a reputation... but they're perfectly decent record players; I collect 'em whenever I stumble across one (typically, in my experience, the belt drives -- at least as freebies); they're the perfect gateway drug for a young'un who wants to "try the vinyls" ;-)
    You done good, IMO! :-)
    You might want to try a P-mount Grado black in there if you wanna spend a few shekels on it...
    EDIT: For best results, use "interconnects" that are low-capacitance, and/or (to be on the safe side) keep 'em short (1 meter or - preferably - even less); else one runs the risk of high-frequency rolloff due to the filtering effect of the cables' capacitance (i.e., in the case of very low-level signals, cables actually do matter) ;-)
