need help with pioneer vsx 1121 with UE22 error
117805363
I have pioneer VSX-1121. I press enter and standby/on bottom and that does not show the reset in the screen. can anyone tell me if there is any steps i did wrong? so that is why reset is not show up
I had problem with UE22 error, i want to see if reset will fix the problem
also i see someone says that update firmware may also slove the problem. then i try to update it over internet, but receiver is always power off duing the middle of updating. then i try to download to my usb to update it, it has same problem, and after couple times it show update error 1.
Post edited by 117805363 on
Have you made sure to unzip the file before putting it on the usb drive? It is not a surprise to hear you have had no luck doing the upgrade over the internet. I do know the firmware update file is large enough to be zipped when you download it. If you haven't already tried, try unzipping the download before you put it on your usb drive. If you can't get it to work and there are no answers that work here on this forum, there is a 1121 owners thread over on the AVS forum with about 110 pages of questions/answers on it. Google the forum and yo should be able to find an answer there. If you call Pioneer, they will not care. Sad, but true. Hopefully someone here can help you, there are a lot of experts on this forum, thats what keeps me coming back.
i did unzip in my usb drive other else it wont able to update. and yes, you are right about pioneer customer support, they say they have no idea too and told me go to the nearest service center which is around a hour drive to see if they can fix it.
at first i didnt want to update. i only update because the i cant reset it, the instruction says that press enter and stand by will show reset option. i try couples time but it never show reset, then i see somone says that update may fix the problem too. then i try to do it
You can search my earlier posts regarding this same issue. I was able to load firmware, reset and continue using the device for a couple of weeks before it completely died. It's basically garbage now. HDMI board replacement (most suggested issue point without paying for an actual analysis) costs just as much as the whole device did new. I know people like their Pio products. For me, not going to be trying them again any time soon.
