Elan Digital Dual Tuner (DTNR)
zingo
I'm only using the Squeezebox these days for radio, and this tuner works great for any AM/FM signal, but also have two sets of outputs. This means it can be run for multi-room as well as being a single source. It's not a very heavy component, so should be a pretty easy and cheap ship. $100 plus shipping
The DTNR provides two independent FM/AM tuners that has 30 AM and 30 FM presets for each of its two turners that can be accessed using the front panel; That's a total of 120 radio presets! The DTNR's sensitivity, separation and signal-to-noise specifications are on par with the finest stand-alone tuners on the market, making for clear reception in all areas.
Features:
Dual digital AM/FM tuners in one component
Direct-access tuning
30 AM/30 FM Presets per tuner (120 total) accessible from front panel
16 custom-named AM/FM presets per tuner accessible from any VIA! Touch Panel
RS-232 control provides 2-way feedback to VIA!s
IR controllable from front panel or with direct IR input on rear
2 discrete code sets for individual control of each tuner
Easy setup
User friendly
Memory backup stores presets even when the unit is unplugged
Power Requirements: 120VAC, 60Hz
Power Consumption: 12 Watts
FM Tuning Range: 87.5MHz to 107.9MHz (20kHz steps)
AM Tuning Range: 530kHz to 1,710kHz (10kHz steps)
Frequency Response: 30Hz to 15kHz +/- 1.5dB
Dimensions:
Width: 17 1/8"
Height: 3 3/4"
Depth: 10 5/8"
Weight:10 lbs
Features:
Easy setup
User friendly
Dimensions:
Width: 17 1/8"
Height: 3 3/4"
Depth: 10 5/8"
Weight:10 lbs
Post edited by zingo on
