NAD 2400 vs Parasound HCA 1000
Easy Runnin
Do you think it is worth it to move from a NAD 2400 to a HCA 1000? Will be used to drive my 1Cs.
NAD 2400
POWER AMP SECTION
Continuous output power into 8½ * 100W (20dBW)
Rated distortion (THD 20Hz - 20kHz) 0.03%
Clipping power (maximum continuous power per channel) 130W
IHF Dynamic headroom at 8½ +5.7dB
IHF dynamic power (maximum short term power per channel) 8½ 370W (25.7dBW)
4½ 400W (26dBW)
2½ 440W (26.4dBW)
Damping factor (ref. 8½, 50Hz) >100
Input impedance 20k½ / 600pF
Input sensitivity (for rated power into 8½) 1V
Frequency response 3Hz - 100kHz / +0, -3dBdB
Signal/noise ratio ref. 1W 98dB
ref. rated power 118dB
THD (20Hz - 20kHz) <0.03%
Bridged Mode
Continuous output power into 8½ * 200W (23dBW)
IHF Dynamic headroom at 8½ +6dB
IHF dynamic power (maximum short term power per channel) 8½ 800W (29dBW)
4½ 880W (29.4dBW
HCA 1000
SPECIFICATIONS
Continuous Power Output - Stereo:
125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven;
200 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Continuous Power Output - Mono:
400 watts RMS, 20 Hz - 20 kHz, 8 Ω
Current Capacity:
45 amperes peak per channel
Slew Rate:
>130 V/µsecond
Power Bandwith:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
< 0.03% at full power; < 0.01 % typical levels
IM Distortion:
< 0.03 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Interchannel Crosstalk:
> 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Sensitivity:
1 V for 28.28 V, THX Reference Level; 1.1 V for full output
Input Impedance: 33 k Ω
S/N Ratio: > 116 dB, full power; > 96 dB, THX Reference Level
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
w 17 1/4" x h 3 1/2" x d 13 1/4", h 4 1/8" with feet
Net Weight:
22 lb
NAD 2400
POWER AMP SECTION
4½ 400W (26dBW)
2½ 440W (26.4dBW)
Bridged Mode
4½ 880W (29.4dBW
HCA 1000
SPECIFICATIONS
Current Capacity:
Slew Rate:
>130 V/µsecond
Power Bandwith:
IM Distortion:
< 0.03 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Input Sensitivity:
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
Net Weight:
22 lb
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Post edited by Easy Runnin on
I have a hca 1000a on the way. Will let you know my impressions
For what it's worth I switched out my NAD 2150 for my Parasound HCA-750A and noticed a VERY distinct difference. The 750A produced a less harsh sound, more blended sound stage, and warmer sound. I was more than a bit surprised. I'm using a NAD 1020 pre and Polk Monitor 5.
