PJ newbie question
Dabutcher
How do I get over air TV on my projector Benq 1070? I have some PS3s that I can get everything else. Thanks. D
Post edited by Dabutcher on
Well if you cannot hook up your cable bx via hdmi then your going to need something like this http://www.epvision.com/HDTVSTB/phd8vxmain.htm
Do not have cable or a box. Thank you PFB. Good luck w job search. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Just need an ATSC tuner of some sort.
http://www.crutchfield.com/S-QTNdzxzHaip/p_659CM7001/Channel-Master-CM-7001.html
Probably not the cheapest, but I didn't look terribly long!Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
If you're committed to using your ps3, then a HDhomerun will do the trick:
http://www.silicondust.com/forum2/viewtopic.php?t=14189
If you're interested, I've got an older model, PM me and I'll look into whether it plays nice with the PS3.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
