Resistance Checks
roderplex
I have a pair of 2.3tl speakers and would like to conduct resistance checks of the speakers. I have read through the troubleshooting guide, but do not see a reference to 2.3tl. There is a reference to SDA SRS 2 and 2.3. Can someone please help me with the correct expected resistance readings?
Thank you,
Russ
Thank you,
Russ
Post edited by roderplex on
I suppose the troubleshooting guide was never updated to include models made after publication of the Guide.
Use the 2.3 figures/specs; and see how close you are. It's not like the drivers were made all that precisely; the MW6509s in my 1B will vary about 1.5 ohms from highest to lowest resistance. If the drivers aren't made consistently, the overall resistances won't be perfectly consistent, either. -
Thanks. I planned to take the readings and compare with them all in the guide. I would imagine that if something is not right, it will be obvious.
