Anthony Gallo 3.0 low output problem on right speaker
polkfarmboy
Need help on this one as I have no idea's of my own on how to remedy a problem I am having.
My right Anthony Gallo 3.0 tower has the two 4 inch mid drivers, the bass driver and the tweeter. Well I notice by my ear and also touch that there is less output coming from the right speakers two four inch drivers. They are playing but with way less bass, does anyone know what this could be? Can the drivers be blown? or could the crossovers have a loose wire?
I really wish there could be no sarcasm and only folks chiming in with similar problems and solutions but its just not gona happen lmao dammm!!!!!!. Anyways guys please try help me out because I really love them and wana try get them back in action.
Post edited by polkfarmboy on
Are you using a tube amp? after I moved my new tube amp to other room 1 channel was softer then the other and I re-biased my tube and it fixed it. as one was 55 the other dropped to 48... did you swap speakers to see if it was still doing it? so to see that its not the amp or cable or source?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
No this is on solid state wyred 4 sound.
have you switched you left & right cable where they plug into you amp? to see if the problem moves over to other speaker?
I know that sick feeling when you think you may have hurt you most loved speakers....got my fingers cross for you brother, that it is only something simply.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
No I switched them and its for sure isolated to the one speaker with all diff types of gear. I would open them up but I dont know what I would be looking for? I dont know why the two of the drivers would have the same low output so maybe they are no blown, who knows.
