Parasound HCA 2200
astar13656
astar13656 Posts: 164
edited July 2014 in Electronics
I have a HCA 2200 (non mkii) that has a sticker with 220V hand written on it by the ac plug.
Anyone know how to check if it is 220 or 110?
Post edited by astar13656 on
    pitdogg2 Posts: 27,368
    edited July 2014
    how about looking at the plug? 220 plugs are different than 110 plugs.
    post a picture.
  • astar13656
    edited July 2014
    It came with a 110 cord/ plug.
    edited July 2014
    well then I don't think it could be 220. Plug it in if it has 110 plug worst that could happen would be it won't work. Now if it were 110 and you plugged in to 220 well that may be a different story. you know you could also give Parasound a call they will be receptive to your call and help.
    EndersShadow Posts: 17,723
    edited July 2014
    Yup. I emailed them about if their HCA-1200ii could handle my Infinity RS-II's and got a very quick reply from them on that topic with all the info I needed.
  • astar13656
    edited July 2014
    I plugged it in and it did not operate properly, so I passed on it.
    Thanks,
    Albert
