Finding a cartridge/needle - Need Help
boston1450
boston1450 Posts: 7,758
edited July 2014 in Electronics
Im trying to find a cartridge/needle for a Technics SL L92 one of those track-close the cover jobies, im not good at the cartridge finding thing & thought this would be the place to ask. Any help would be appreciated. Would like to keep the cost as low as possible. Thanks In Advance. Randy
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
    SCompRacer Posts: 9,088
    edited July 2014
    Has that got a P mount cartridge on it? They just plug in, unlike a standard 1/2" mount that secures with two vertical screws, although P mounts may have a horizontal screw/nut to secure cart in arm. Check out a place like LPGear or Needle Doctor for cartridge. Even Amazon.
    1/2" mount top, P mount bottom.
  • boston1450
    edited July 2014
    Yes they just plug in. I have manual. There is no cart on it - not sure where it went as i just purchased the unit :( i looked around & i came up with Audio Technica ATN3272 (i think) if i recall. I looked at needle doctor & too confusing
    Randy-Maine
    by David WMG
    edited July 2014
    The P mount page at ND. You have from lower to higher quality with different stylus options.
    http://www.needledoctor.com/Brand-Stores/Audio-Technica-P-mount-T4P-Cartridge
    If you want to stay real inexpensive, you can find an Audio-Technica AT90CD for around $20.
  • boston1450
    edited July 2014
    Thank you. I appreciate the help. I will take a peek
    Randy-Maine
    by David WMG
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited July 2014
    Options limited with the p mount, but is easy to plug and play. Go with the cheap AT mentioned above first to make sure table is working right and then you can upgrade to a better cartridge. I think the Grado Blue is probably as far as I'd go quality and price wise for any p mount turntable. YMMV
  • boston1450
    edited July 2014
    ^^^ ordered one 37.XX earlier. Cant wait to get it & see if it works properly. Not exactly sure why it wasnt there. Original owner sold me receiver-cd player-turntable for 20.00 so i didnt get hurt too bad. It is new in the box-although it had been opened by original owner. Even had cardboard/felt lining was all still in place. Maybe it was-buy the unit & select a cart when you bought it ? I do know in the manual it states it is not installed & i had to remove all those little plastic clips & guards off tone arm.. I did notice the speed is way too fast. Not sure if that is because it does it AUTO. Got to get more read on. Thanks all. I will update once i get the cart ( week or so ? )
    Randy-Maine
    by David WMG
    edited July 2014
    There are some decent Ortofon Cartridges for P-mounts. I run one myself on a table with good results, but it's not a linear tracking table.
    Here's a P-mount for a Linear table that looks good. It should be child's play to replace these.
    It is also my understanding that Technics, before it left its TT days behind, actually considered the P-mount the FUTURE in TTs. And was getting ready to go all in on P-mounts assuming that cartridge makers would follow suit and start producing Higher End cartridges for such tables because they were HASSLE free. No need to mess with tone arm weights, tracking, anti-skating, protractors, and any number of things that make TT aficionados swoon and faint! lol
    http://www.turntableneedles.com/ORTOFON-OMP5E-P-mount-Phono-Cartridge-for-Linear-Trackiing-Turntables_p_3928.html
    cnh
  • swethawell
    swethawell Posts: 3
    edited July 2014
