Adcom advice
kingkip
Anyone ever used adcom? I found a good deal on the 7807 (I think that is what it is) 7x300. Just wanted to know if anyone listed to it or other adcoms.
There are two ways to argue with women. Both of them are wrong.
Post edited by kingkip on
It's gennerally considered a very good entry level brand, with regards to seperates. No harm in auditioning it.
Adcom is awesome! Check em out!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Geez Sid. You're slipping. It took you a whole 23 minutes to jump on this one -
yeah.........I'm talking to my Dad......lol, not really paying attention- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I currently own the GFA-7700 and find it lacks the Bass authority I was used to when I was driving my M10's with the Carver CM-1090. Then again, it could be that the Sony TA-E9000ES pre/pro doesn't mate well with the Adcom.
Dan -
i own the 7607 it is a great amp and sounds good with my sunfire.
Hey another dude from the Northwest!
I use a two channel Adcom myself... much smaller than the one you are talking about. I find that it has plenty of power. but appears at least mine seems kind of bright and harsh. Amps are heavy pieces of equipment.. i imagine that amp weights more than my car.
demo it.. and see if it sounds good to you. demo it against others in it's price range.PolkFest 2012, who's going>?
