ROTEL RX-855 has very low sound.
Mystery
I have to turn volume to max to hear faint music.
Is the amp out?
What else to check?
I tried different inputs.
Even FM behaves the same.
thanks for ideas.
Is the amp out?
What else to check?
thanks for ideas.
Post edited by Mystery on
Okay will try that and apply some deOxit.
If it works, I can replace Luxman 113 in my bedroom with it.
Haha... so funny.
Loose jumper pins were not the issue but related...
Anywho, now I have sound from only right side.
I swapped interconnect channels, speakers but only right side is working.
Could be fuse inside.
That's next thing to check.
Pre-out worked on both sides but I couldn't fix the left channel.
Or I have no idea what to fix so it went to local guy who said to fix and use it.
