Response Audio 3205 Extreme with Clarity Caps (Modified Jolida)
shadowlight
For sale is Response Audio Modified Jolida 3205 Extreme with Clarity caps. Purchased directly from Response Audio about 18 months ago. It can be used as integrated amp or power amp. The switch labeled balance is used to convert it from integrated to power amp. When the switch is up it runs as integrated amp and when it is down it is power amp. The right most input (labeled tuner) is used for power amp mode.
Review of the older Extreme with Soniccap - http://www.enjoythemusic.com/magazine/equipment/0307/bella_extreme_3205.htm
Unit that I am selling is similar except when I purchased it Soniccap's were not available so Clarity MR caps were used by Response Audio.
Has taps for 4/8ohm speaker, will work with 16ohm speakers also. Currently, used to drive Zu Druid V speakers.
Supported Power Tubes: EL34/KT77/6CA7, KT88/6550/KT90
preamp/splitter tubes used: 12ax7 and 12at7
Tubes included with the sale are - standard Svetlana EL34, 12at7 and 12ax7 provided by Response Audio, Penta Labs KT88 and TungSol 6550 tubes.
Price - $1,000 + shipping, no paypal fees, the amp is heavy so would prefer local sale 08540
Post edited by shadowlight on
Correct on the when it was purchased. It was purchased about 24 months or so ago.
That is a great tube amp for $1k. Someone needs tubes!!!
GLWTS.Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server -
GLWTS.
Thx Bikerboy.
I have 2 other tube amps (both SET) and this one get's used the least.
I am not sure what is going on but I am not getting any alerts when folks post in the thread so if I do not respond please send me a PM. -
Set.....mmmmmmmm
They are hard to replace once you get them, but they are a pita to match properly for those of us who do not favor horns.
The speakers that I use the SET amp's with is Zu Druid V.
The first SET amp is the Ming Da 3000 abse integrated with 805 power tubes
. The Ming Da is a space heater so it gets used during the winter months the most :-)
the second is 2a3 base from small Canadian company Triodelab which is straight power amp and the preamp that I use with that is Dodd Audio's 6h30 battery power.
How do you like your 845 SET amp? -
Bump
