Turntable Stand
gudnoyez
gudnoyez Posts: 8,183
edited July 2014 in Electronics
http://www.audioadvisor.com/Sanus-EFAB-Amp-Floor-Stand_Base-Module/productinfo/SAEFAB/#.U8GEIZBOXIU
Ok I just ordered one of these for my Amp, will one one of these work for a turntable? I want to keep my entertainment center un cluttered, in this order bottom My AVR, Next Shelf Panamax, next Oppo 105, top shelf Center channel tv wall mounted right above center. To the left on amp stand on floor 3 channel amp to the right on floor on another sanus stand with turntable. Everything will be organizedand look pretty cool, is it ok to put a Turntable on one of these stands on the floor? If not can someone recommend a turntable stand?
Post edited by gudnoyez on
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited July 2014
    I'm not sure but the stand won't work with Emotiva amps.
    edited July 2014
    Not sure about that, but it will accommodate my 5503 just like the one pictured however I'm sure an Emotiva would rest just as well on that stand, just wondering how another one would be for a turntable.
  • [Deleted User]
    edited July 2014
    I have my TT on something like that out of necessity but I don't know if I recommend it.
    I was going to say Crown amps but I didn't want to crash the site.
    gudnoyez wrote: »
  • pumpkinman
    pumpkinman Posts: 10,399
    edited July 2014
    I think if you have any DIY skills you'd be better served with a sand box
    http://www.polkaudio.com/forums/showthread.php?67003-Turntable-Isolation-Sand-Box
    Because I am The Pumpkinking
  • Jhayman
    Jhayman Posts: 1,548
    edited July 2014
    I use 80lb solid Granite slabs, 12"x18"x3" as my Amp stands..
    Great price of $37.99 each
    Here's my pic gallery on CAM..
    http://www.canuckaudiomart.com/view_userimages.php?user_id=28601
    edited July 2014
    http://www.audiophilia.com/hardware/diyttstand.htm
    Here is a beck of an idea I found over at Steve Hoffman's just need to paint it black, anyone know where to get some black paint? Seriously heavy and good isolation I should try this out!
  • pumpkinman
    edited July 2014
    gudnoyez wrote: »
    It would certainly be cheap enough. What the heck give a try and let everyone know what you think.
  • Jhayman
    edited July 2014
    Be careful about if you have any Cats they might like it up there..lol
  • brgman
    brgman Posts: 2,859
    edited July 2014
    I have my VPI Scout on a Sanus stand.I use 4 Isolation blocks and a 3 in thick maple block that it sits on.
    Been very good to me.
    I’M OFFENDED!!!!
