RCA cables
jumper314
jumper314 Posts: 7
Hello everyone, I need a little help here. What type of RCA cable do I use to hookup an amp to a receiver. Is there different kinds, or they all do the same job. I'm hooking up an adcom amp to an Onkyo receiver, to power Polk audio speakers. Thank you Joe
Post edited by jumper314 on
  • Speedskater
    Speedskater Posts: 495
    edited July 2014
    RCA interconnect cables can serve several different purposes:
    a] Mono analog audio. (1 cable)
    b] Stereo analog audio Left & Right (Red & White)(2 cables)
    c] Composite video with audio (Yellow w/Red & White)(3 cables)
    d] Component video but no audio (Red, Blue, Green)(3 cables)
    e] Component video with audio (Red, Blue, Green)(Left & Right)(5 cables)
    f] Digital audio (1 cable)
    In general any cable will serve any purpose, but often cables are optimized to a labeled purpose.
  • jumper314
    jumper314 Posts: 7
    edited July 2014
    So (b) is my best option.
    F1nut Posts: 52,017
    edited July 2014
    You want RCA cables for audio, sometimes called patch cords. Generally they are marked on the terminations with the right channel red and the left channel white. However, some makers use different colors. You can buy generic versions for next to nothing or you can spend north of $10,000.00. I suggest something better than the generic version.
  • Thorton
    Thorton Posts: 1,324
    edited July 2014
    +1 to F1's recommendation... better than generic. If you tell us a price range you want to spend we can give you good suggestions.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • jumper314
    jumper314 Posts: 7
    edited July 2014
    Thorton wrote: »
    I guess 50.00 to 100.00.
  • Thorton
    edited July 2014
    Others will chime in but Blue Jeans Cable or Signal Cable are good recommendations. Signal Cable usually gives a Club Polk discount. I have Signal Cable interconnects and have been very happy.
    DAC: Bricasti M1SE
  • jumper314
    jumper314 Posts: 7
    edited July 2014
    Thank you everyone!!! Great advice and product info.
  • jumper314
    jumper314 Posts: 7
    edited July 2014
