Subwoofer for Rtia3
gaetanoformato9
gaetanoformato9 Posts: 19
edited July 2014 in Speakers
Hi, some time ago, thanks to your advice, I purchased a pair of Polk Rtia3, amplified by a yamaha a-s500. I think it's time to add a subwoofer, which you believe will match better with Rtia3?
Thank you
  • ken brydson
    ken brydson Posts: 9,106
    edited July 2014
    Lot's of questions before we can make a recommendation. For music or movies (if both %)? Room size? Openings into other rooms? Listening habits? And most importantly BUDGET??
  • gaetanoformato9
    edited July 2014
    It's only for music, the room is about 16 m^2. I don't have a fixed budget, under € 300 would be fine but i can wait and spend something more, but I want to avoid taking something of quality too high / low compared to Rtia3. In short, I'm looking for a subwoofer good enough not to degrade their sound but not exaggerated compared with those speakers
  • ken brydson
    edited July 2014
    For music I'd go with a sealed design. Can you convert your budget to $$?
  • gaetanoformato9
    edited July 2014
    Yes, it should be around $ 400
  • ken brydson
    edited July 2014
    Where are you located?
  • gaetanoformato9
    edited July 2014
    I didn't understand, you mean the country? Italy in this case :)
  • ken brydson
    edited July 2014
    Yeah, country. Just asking because SVS has some sealed subs in their clearance center but I'm not sure if they ship overseas.
    http://www.svsound.com/specials/outlet-specials
  • gaetanoformato9
    edited July 2014
    If I have understood correctly they ship overseas but shipping would be very expensive due to import taxes.
    There is a dealer in Italy: http://svsound.it/
    But I see that prices are quite high, however, is there a specific model that you advise me of this or another brand?
    gudnoyez Posts: 8,223
    edited July 2014
    http://www.svsound.com/merlin
    SVS recommends one of these as a match to your RTIA3's
    edited July 2014
    Just put in Polk Audio for make and RTIA3 for model and it will give you 3 choices that are recommended to match your a3's
  • gaetanoformato9
    edited July 2014
    Among the subwoofer recommended by SVS the cheapest is the SB-2000, and costs $ 700. But it's worth taking a subwoofer that costs $ 700 and match it to Rtia3?
    edited July 2014
    I run dual subs Polk Psw111s with RTIA5' s and RTIA3's s and I'am quite happy with them, that being said I would love to have one of those subs that SVS recommends, for your A3's.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2014
    I would say yes.
    I had the RTiA3s and was using a sealed subwoofer design that cost close to $600 US and it was definitely worth it.
    A good musical sub will anchor the whole soundstage making it more spacious, the low freq performance will match nicely with the extended clear highs of the RTiA3.
  • deronb1
    deronb1 Posts: 5,021
    edited July 2014
    NHT makes some nice sealed subs. 10" & 12"
  • gaetanoformato9
    edited July 2014
    Okay, perfect, thank you all for the advice, I will wait and consider the SVS SB-2000 or a NHT sub now that I know it's worth it :)
