Dreadnaught cables
jonicont
I could use some help. I am attempting to make my own cables. Outside of Larry's rings, it's my first DIY project. I have the NL4 connectors. I think I'm clear as to what to do on the transformer side
Red/Yellow (right pin) to 1+
Black/Orange (right blade) to 1-
Grey/Brown (left pin) to 1+
Blue/Violet (left blade) to 1-
I have a question about the speaker side. Do I connect the blue wire to 1+ and the white wire to 1-. And do I leave the connection to the binding post intact?
Will also be adding new binding posts and Vr3 plates but that seems pretty straightforward
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
Post edited by jonicont on
You've got it figured correctly, and yes leave the jumper connected to the binding post.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Thank you sirDynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
