PSW 50-Batting Material
Tony Go
Hello All,
I just had the driver for my PSW 50 reconed as I blew the spider and coil out of alignment. I also noticed that the batting material was a little funky so I replaced that too. Is there a "magic" quantiy of batting material to use to achieve optimum sound?
Thanks,
Tony
Thanks,
Tony
Post edited by Tony Go on
No magic amount, just line the walls with about as much as before. Keep it away from the port openings and you will fine.Graham
Thanks Gatemplin--Does anyone know the function of the material?
