Thicker Rug Pad Improve Acoustics?
DForeman
DForeman Posts: 468
edited July 2014 in DIY, Mods & Tweaks
I am trying to tame some brightness in my family room and read online somewhere that using a 1/2" thick pad under an area rug instead of the typical 1/8" would help. The room in question has high ceilings and hardwood floors. Since it is the main room in our house, using panel treatments and bass traps etc. is not an option.
The rug is 10x13 and directly in front of my speakers.
Is this worth a try?
Parasound P5 Pre
Marantz AV 7703 Pre/Pro
Outlaw 7500 Amp
Marantz SA14s1 SACD/CD
Rega Planar 2 TT
Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
Oppo BDP-103
Post edited by DForeman on
  • codyc1ark
    codyc1ark Posts: 2,539
    edited July 2014
    Why not some of the custom printed panels? You can really get anything you want, might be worth a shot to run by the wife.
  • DForeman
    DForeman Posts: 468
    edited July 2014
    codyc1ark wrote: »
    Didn't realize you could get a custom print. I'll check that out. Thx Cody
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
  • DForeman
    DForeman Posts: 468
    edited July 2014
    Hermitism wrote: »
    Wow. Some nice stuff. This changes everything. Thanks!
    Parasound P5 Pre
    Outlaw 7500 Amp
    Rega Planar 2 TT
    Oppo BDP-103
    F1nut Posts: 52,017
    edited July 2014
    DSkip wrote: »
    Treating your first and second reflection points will decrease your treble incredibly. I've also treated the area directly behind my head. The benefit of treatments is that it not only tones down the brightness, it stabilizes and (in my case at least) widens your soundstage, improves imaging, and any changes you make in your system have a greater effect.
    You got any hard evidence to back that up? What about blind tests? I mean, you know it could just be the placebo effect.
    F1nut Posts: 52,017
    edited July 2014
    Eh, I'm just effing with the naysayers. :cheesygrin:
  • GlennDog
    GlennDog Posts: 3,158
    edited July 2014
    DSkip wrote: »
    How does one calculate the 1st & 2nd reflection points ?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • zane77
    zane77 Posts: 1,696
    edited July 2014
    You can use a mirror to find the reflection points
    Two Channel
