PSW350 Hook-up
Firerider58
Firerider58 Posts: 95
edited December 2001 in Technical/Setup
Once again I need some help from the pro's. I just got my 350 the other day, and here's my question. Is there any real, noticable difference in performance by wiring your reciever into the input jacks and then having your fronts run from the outputs? I went the lazy mans route the other day and currently have it hooked into my Onkyo 494 with a Monster Cable via the LFE input. It sounds decent, but if it would sound markedly better the other way, I'd be willing to run a little more wire. I'm using 800I's for my fronts. As alway's,,,thanks for any advice.
Ron
Post edited by Firerider58 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I had close to the same setup, I think the LFE out to the sub, with the 800's as mains set to large is the way to go. The 800's handled everything I threw at em'. End of story.
    Cheers,
    Russ
    Texas FireFighter eh? Thanks for doing the job you do brotha....
  • juice21
    juice21 Posts: 1,866
    you could try it and see what you think....
    i don't have the 350, but mine is set the same way as russ'. LFE to sub, 800's to large...
  • OrangeToupee
    OrangeToupee Posts: 488
    Same here as well, except I have my 800i's set to small (suggested by Denon receiver manual) and sub picking up everything under 80Hz. I don't know which I prefer yet, I'm still experimenting with the sound.
  • ntculenuff
    ntculenuff Posts: 1,146
    i would set your fronts to large they can handle the frequency range. the denon manual prob suggested the small setting as most people have smaller speaks.
    i have older rt10's set to large they can take any thing i give em'
    my front stage sounds fuller with my mains and center running on the large setting
    GOD I LOVE MY POLKS :D
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • Firerider58
    Thank's for the pat on the back Bro! I just look at it this way. I have a great job that I've been fortunate enough to enjoy for almost 15 years. Regarding the sub, unless someone tells me that it will make a mammoth difference, I think I will stay with the setup I have now. Besides, I dropped some coin on that cable! Thank's for the input. Where are you at in the great Lone Star State??
    Ron
    P.S. Are'nt you the guy that rubbed TOMB RAIDER on his arse crack?? Man! You are my kind of critic!! :D
  • TroyD
    TroyD Posts: 13,124
    my .02 is that using the LFE is just fine, set your fronts to large and let 'em rock.
    ditto what Russ said, my hat is off to you......
    Troy
    ....and yes, Russ is the man!
  • RuSsMaN
    Bout' 20 miles north of Big D.
    Cheers,
    Russ
