PSW-50 problem?
David Finateri
David Finateri Posts: 4
edited December 2001 in Technical/Setup
Does anyone have an idea why the subwoofer (PSW-50) works fine for a few minutes then switches to standby mode. When a commercial comes on (usually a hotter signal) or a stronger bass signal,if on radio or CD, it will come back on. It may work fine again for a 1/2 hour or maybe just a couple of minutes.
I am using an Acoustic Research subwoofer cable from an Onkyo TX-DS 575 and a like brand "y" into the back of the sub.
Thanks in advance
Dave
Post edited by David Finateri on
  • juice21
    juice21 Posts: 1,866
    i am not too familiar with a psw50, but the other polk models have an auto on/off mode. where, if the sub does not recieve a low frequency after 5-15 minutes (whatever the respective time is set to) it will power down, until it reaches it's next low frequency signal. check the back of your sub, if it set to auto on/off, just switch it to the non-auto setting. so when you turn everything else on, you'll reach around and turn your sub on too. just remember to shut it off with everything else too. the auto on/off is to avoid this constant powering on and off manually, and the save electricity, but if it annoying to you, and you have the option to turn the auto off, try it, and you shouldn't have your problem anymore!
  • ntculenuff
    ntculenuff Posts: 1,146
    i was having the same prob with my definitive sub, it would power off while i was watching a movie with little lfe signal it drove me up a wall. i e-mailed definitive and they sent me a kit to increase the auto on/off from 10 minutes to 35 minutes and increase the low frequency sensitivity it picks up almost immediately. much happier now.
    maybe polk has something like this for there subs
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Splain man.
    What was in the kit, what did you do?
    Cheers,
    Russ
  • ntculenuff
    Chet is the tech there at definitive super nice guy, he sent me 1 new resistor and 2 new capacitor and a few simple diagrams and instructions. so when it arrived i grab the trusty solder iron and went to work took about 15 min.
    basicly this is what i did:
    replaced:
    1) a 10uF 50v electrolytic capacitor with a 22uF 35v electrolytic capcitor
    2) a 1k¿ resistor w/ a 475¿ resistor
    3) a .1uF 50v ceramic capacitor w/ a .33uF 50v ceramic capacitor
    it was actually quite simple.
    i had e mailed him about it turning off and such and he e mailed me with a few diff options and this was one. Tried the others but liked this idea much better
    the only other option i can remember was turning the gain down on the sub and increasing the sub volume on the rcvr.
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
  • ntculenuff
    the upside down ? mark is an ohm symbol in word.
    guess the forum font doesn't recognize the symbol :rolleyes:
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
  • David Finateri
    replaced:
    That sounds like the fix for me. I suppose I should try to hunt down some schematics. I have the reciever volume maxed and turned the gain down on the sub, this works better, that's why I think increasing the timer is the way to go.
    Thank for the help!
  • jcaut
    jcaut Posts: 1,849
    This sounds like a good question for Polk customer service.
    Keep in mind that some receivers will clip the subwoofer output at high volume, if the sub volume on the receiver is cranked up too much.
    Jason
  • ntculenuff
    David Finateri
    i would just call the polk cust service, dont see why they wouldnt have the same sort of thing
    good luck
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
