question on Panamax MR 4300
gudnoyez
gudnoyez Posts: 8,183
edited June 2014 in Electronics
Question it has 8 outlets on the back and 1 on the front if a hook up my AVR, 3 channel amp, Oppo 105, my Tv, both subs, and a turntable, will they all be equally protected? I know it can accommodate 9 pieces of equipment, but is that running to much on it and would I want to throw another one in the mix? All answers are appreciated, I just want the best protection for my gear.
Post edited by gudnoyez on
  • rpf65
    rpf65 Posts: 2,127
    edited June 2014
    Yes, the protection is equal for everything plugged into it. Think of it this way; your buying a really expensive, high-tech fuse. Since this fuse is between line voltage and all gear plugged into it, get a power surge and fuse blows. The circuit from line voltage to gear is now open. All loads are disconnected, so all are equally protected.
    edited June 2014
    I have a receptacle close to the one where the Panamax is I could put the amp in that one with a decent plug in wall surge I see Panamax does offer those types. Thanks for the answers.
