Oppo 103: Q regarding active speakers
OldSchoolPolk
OldSchoolPolk Posts: 159
edited June 2014 in Electronics
Hi all,
I'm looking at using an Oppo 103 with active monitors for a bedroom system to have a 3.0 or possibly a 3.1 system. I've read conflicting reports about the 103 having a slight buzz when doing so. Has anyone in this forum tried it and what did you find?
I'm trying to make the system as simple as possible and would like to eliminate the HT receiver.
Thanks,
Bryan
HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
Post edited by OldSchoolPolk on
  • Talon_Sr
    Talon_Sr Posts: 125
    edited June 2014
    Hi, I'm curious. What is the 103 going to? Directly to your speakers? If so, is it via RCA or do the speakers have HDMI? You probably know this already, but with the 103, you can run dual HDMI out (one for video and one for audio). So you may want to try that if you do get some hum. I'm running my 103 this way with one HDMI going to AVR and the other going directly to TV (bypassing the AVR's video processing) and do not have any hum or buzz. Unfortunately, I can't comment on experience with hooking the 103 directly to powered speakers. But I'll be watching this thread. I'm interested in how it well it would work.
    Pioneer SC-1523-K and VSX-1018AH-K; Polk Monitor 75T Fronts, Pioneer S-HF11C Center, Cerwin Vega VE-5M surrounds and backs; Polk PSW-505 with Mediabridge SW cable; Onkyo SKW-204 with Mediabridge SW cable; Oppo BDP-103; Akai GX-255 Open Reel.
