Center Channel for RT1150s
AsSiMiLaTeD
Is there anything other than the CSi30 or 40 that I should be looking at?
How feasible is it to mount on of these on a well?
Post edited by AsSiMiLaTeD on
what type of well??? oil,water.... they sound great mounted onto a water bucket. Just hoist it half way down the well to get the right frequency.Fronts-Rti100's / Rt55i's
Center- Csi40
Surrounds-Fxi50's
2-PSW303's
WANT A SVS REALLY BAD! -
Get the 40 it will give you the deeper and wider sound needed for a better match for the 150's. Mounting them to the wall would not be a good idea (too heavy and large) put it on a shelf above the tv or if poss under it. There is no good way to do it without a shelf.
Dave
