Calling all SDA SRS 2, SRS 2.3, SRS 2.3TL Owners
MAD
MAD Posts: 105
edited June 2014 in Vintage Speakers
After reading through many posts, I am now confused.
Some have said the SRS2 have more bass than the 2.3 (maybe a bad pair of 2.3 or do the srs 2 have more in terms of ratio between bass : mid/treble) . I know the 2.3 will output more volume when cranked but at average listening levels will the SRS 2 seem to have more bass?
I want to own 1 pair of SDA's at this moment, do the upgrades and be happy, as I have a bit of a speaker addiction problem.
Some of you have helped me out in the past, and I appreciate all the input, if you could give me your opinions.
I am deciding between the
a)sda srs 2 blade/blade (going to do the rod 198tl mod and at least daytons in the upper portion of the crossover)
b)sda srs 2.3 (going to do the rdo 194 mod and at least daytons in the upper portion of the crossover)
c)sda srs 2.3tl (going to do the rdo 198 mod and at least daytons in the upper portion of the crossover)
I currently own the sda srs 2.3
I usually listen to the 2.3 with the bass knob on 5 out of 10.
I love the width and height of the soundstage of the SDA 2.3.
Listen to rock, hip/hop, some rap… I love bass.
I listen at low to medium volumes (1w to 30wpc on the output meters of the amp) and occasionally crank it. \
Probably max 90db.
People rave about the rdo 198 and I do love sweet detailed treble.
I'm sure the 2.3 will put out more bass at higher volumes, but some people say polk sda srs 2 have more pronounced bass at a given volume and they were designed that way, is this the general consensus? There are a few posts mentioning that some were let down going from the srs 2 to srs 2.3… is this the case.
I have a few questions
1. Is there a major difference between height and width of the soundstage between the models?
2. Do the SRS 2 actually output more bass (is the bass : mid/treble ratio different between models)?
3. Will I regret selling the SRS 2.3 and going with the SRS2 ?
4. Is the srs 2 TL mod a fairly easy straight forward option?
5. If you could rank the speakers from best to worse?
Thanks in advance for any opinions,
Post edited by MAD on
  • Phatattack
    Phatattack Posts: 30
    edited June 2014
    Toolfan66 Posts: 18,332
    edited June 2014
    The 2.3's lack no bass, and if you feel you are, you need a better amp, and or gear..
    Not sure what your using, but IMO keep the 2.3's and upgrade them, the 2's and 2.3tl's will be minimal gain depending on your gear, and what you can afford moving up the chain in gear.
    Also I see you state you keep the bass knob at 5 so I'm guessing you have tone controls, I personally hate them, and when it comes to using a bass knob it always sounds bloated to me..
    Post what gear you are running to power the 2.3's cables and all.. The 2.3's are a fantastic speaker one of my favorite SDA's and I hate when I see someone pass them up in hopes to land the TL version..
    Again this is my opinion, YMMV
    edited June 2014
    Oh and forget the Dayton's get Sonicaps, and the RDO 194's
  • MAD
    MAD Posts: 105
    edited June 2014
    The gear I'm running as of now:
    Pre amp: Hitachi hca 8500 mk2 pre amp
    Power amp (alternate between): Kenwood 700m unrestored power amp (sometimes running/blending in hitachi ham 8500 for the tweets) / adcom gfa 5800 / rivera hammer 320 tube amp.
    Custom home made interconnects - they sound spectacular I used Cat 5 cables wrapped around rope, taped and wound where either cable never comes closer than a 1/2inch of one another, tri-eutectic solder, 1877 rca jacks.
    ultralink audiophile reference grade speaker cable (got it for free somewhere fairly thick).
    I'm not looking to ditch the speakers, but as I have read different posts (raving about rdo 198 vs 194) and it does make you wonder (I know different setups yield different results and some caps may have not warmed up/ some drivers miswired). Maybe they are tiny differences?
    Thanks for any advice
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited June 2014
    Well, I've owned all three of the models you list. They are all a good example of what the SDA technology has to offer. I have never thought that any of them lacked BASS, the cabinets need to TIGHT (all interior joints re-glued, new gaskets, Hurricane Nuts or Larry's Rings for the drivers) and SPIKED, plus proper placement to achieve the best Bass response.
    I prefer the sound of the 2.3TL's, but that's just me, the RDO-198's do have an edge in the smoothness department.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2014
    The SRS 2 Blade/Blade can't take the 198, it is setup for the 194. I don't recall anyone on the forum ever claiming that the SRS 2 had more bass than any 2.3 model. The bass is created by the mids acting in conjuction with the bass radiators. The 2.3 with 6 mids will always put out more bass than an properly working SRS 2.
    When someone claims that their SDAs aren't producing enough bass, it is usually found to be drivers wired wrong, cabinets have leaks, or drivers aren't working at all, wires have worked their way loose. SDA crossovers are some of the most complicated around and over the years, lots of people have been into the cabinets with little knowledge of how the speaker were designed to work.
    F1nut Posts: 52,244
    edited June 2014
    The 2.3 and 2.3TL's bass is tighter than the SRS 2's, which may lead some to think the SRS 2's have better bass when in fact they don't.
  • MAD
    MAD Posts: 105
    edited June 2014
    Thanks for the replies,
    Toolfan: I will probably end up going sonicaps, but daytons would be the minimum.
    Mike: I have done nothing yet to the 2.3, I'm sure after the upgrades there will be huge improvements.
    Dennis: I read some post where a guy on here changed the cap value to 5.8u of the sda srs 2 (I thought it was blade/blace) in order for it to accept the rdo 198 instead of the rdo 194. I don't know if this is an accepted mod or someone tinkering? I will try to find the post.
    F1: maybe I am mistaking sloppy bass for more bass as at lower volumes it would be perceived as more bass.
    As for bass, it is there and full sounding, but in comparison to my set of pioneer DSS9 which have a 12" ported dual coil graphite woofer, the bass of the pioneers is more satisfying on some track (but maybe more sloppy or their efficiency could help that they put out more bass). Do I enjoy sloppy bass?
    I still feel the polks are the most overall pleasing speakers that offer a tall, wide soundstage that seems alive (as instruments move between and outside the speakers)
  • Mike Reeter
    edited June 2014
    The 2.3's do throw an impressive (wide) soundstage with the four dimensional drivers, I would have liked to have kept mine, but funds dictated otherwise. Part of the magic of SDA's is their ability to turn a studio recording into a live performance.
    Perform the usual upgrades as time and money allows, every aspect of the speakers presentation is enhanced. You will be rewarded for your efforts!
    F1nut Posts: 52,244
    edited June 2014
    Mike, slight correction. The 2.3's have 2 dimensional drivers.
  • Mike Reeter
    edited June 2014
    You don't include the donut drivers as dimensional?
  • Mike Reeter
    edited June 2014
    ZLTFUL wrote: »
    To elaborate, Mike, they are the center 2 drivers on the 4 driver side. The donut drivers play the stereo signal along with the 2 driver side.
    Thanks Ryan, You have cleared that up for me. I was always under the impression that the donut drivers were a part of the "array" of dimensional drivers.
    I still feel like the 2.3's throw a wider stage than the TL models, the TL's have them beat in stereo imaging, at least to my ears.
  • MAD
    MAD Posts: 105
    edited June 2014
    Mike… to confirm from your post you feel the 2.3 have a wider soundstage but miss out on some of the precision of instrument placement?
    Another thing to consider…
    Thanks again,
    I was always curious about the donut driver. I figured the extra mass was to prevent some treble from coming out.
  • Mike Reeter
    edited June 2014
    MAD wrote: »
    Thanks again,
    MAD, Don't let my ramblings sway your feeling toward your 2.3's. They are a very good example of the SDA lineup, I've read where the donuts were added to calm down the mid-range a tad bit.
    F1nut Posts: 52,244
    edited June 2014
    They are actually labeled as sub-bass drivers. As Mike noted, the donuts are used to limit the mid-range frequencies.
  • Tronman
    Tronman Posts: 72
    edited June 2014
    ZLTFUL wrote: »
    I just learned something new!!! I did not know that :-)
  • Karn
    Karn Posts: 21
    edited November 2025
    Very late reply, but reading through some searched links and I have to comment that I have both the SDA SRS 2's and the 2.3's.
    The 2.3's have been resealed, hurricane-nutted, leaked checked etc. I found that the SRS 2's have a significantly wider soundstage than the 2.3's, and while the 2.3s sound (to me) much brighter/accurate on the higher frequencies, that it's missing a significant amount of low end versus the SRS 2's. I put a non-trivial amount of time into sourcing and installing the correct woofers, seals, and nut/bolt combinations because I assumed the lack of sub-frequencies I was noticing on the 2.3's were attributed to air leaks and incorrect woofer models from previous owner attempts at repairs.
    I can't account for it, other than the subjectivity of playing the same track, at the same dB/volume with the same equipment and inputs (amp/dac/cables etc), and noticing the pictures on the walls vibrate significantly more with the SRS 2's than with the 2.3's, and my ears agree.
    Both are on stock crossovers - the 2.3s are using the original SL2000 tweeters, and the 2's are equipped with the RD0194s. I did the A/B tests during the time period I still had SL2000's in the SRS 2's (the SRS 2.3's have since been moved into storage).
    The 2.3's make me feel like I need to add a sub -the 2's need no assistance. I also notice the "sweet spot" for the 2's is much wider than the 2.3's -there's a specific spot I need to sit in with the 2.3's to get the headphone/SDA effect versus the 2's which is more subtle but I feel overall larger.
    I should state that the majority of music I listen to on the SDAs is electronic/up and down tempo/dark synth/synthwave/retrowave/industrial electronic and various metal subgenres. I get the impression that the 2.3s are meant more for vocals and concert hall emulation, which isn't for me.
    F1nut Posts: 52,244
    A friend with the 2.3's has always complained about their lack of deep bass even after modifications.
    So, spit balling here...the donuts were added to the 2 mid-drivers to reduce the amount of bass the speakers could produce because Polk thought they were bass heavy speakers. It would be interesting to swap those mid-drivers out with non-donut versions.
    My personal opinion is the 1C and SRS 2 are too bass heavy making for a bit of a muddy sound. However, for your music preferences they should work well.
    FYI, the 2.3TL's do not lack deep bass nor sound muddy.
