RT800 timbre matching rears
shiyo
shiyo Posts: 1
edited June 2014 in Vintage Speakers
Hello. I want to use my old RT800s as mains for a budget 5.1. I started looking for a center, the closest I could get to was CS350 (probably a failed attempt to timber match). Now I am looking for two rears and I am thinking of getting a pair of OWM3 (receiver is Yamaha rx-475). I don't have a clue on what I am doing. any advice would do. I live in Europe and prices double due to weight
Post edited by shiyo on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2014
    The proper match for them is an FX-300 or FX-500 model.
  • ken brydson
    ken brydson Posts: 8,981
    edited June 2014
    shiyo wrote: »
    CS350 is a decent match as the tweeters are similar, CS 400 or 400i are closer. OWM3's will be fine for surrounds IMO. Also keep an eye out for RT/fx's or LS/fx's. Welcome to CP!!
  • Jimbo18
    Jimbo18 Posts: 2,348
    edited June 2014
    Timbre matching on the rears is generally not considered as important as across the fronts and center. I have RT25i's in the back and am happy with those. I also had RT35i's in the past and they fit the setup well also.
